39 Users Online (37 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> My Stairs are Messed up
Wed, Jun 11, 2008 at 2:38:27 PM | My Stairs are Messed up
relliot
My prolem is that I have two landing before the next floor is reached.  My Revit Arch. 2008 has been sending one or more or the railing at a extremely steep angle.  Everything else seems to be correct but the railings don't like the fact that I have two landings between floors.  Can anyone shed some light on why this is or a way around it to get my stairs to work properly, I'm running out of hair to pull out.
Wed, Jun 11, 2008 at 2:50:24 PM | My Stairs are Messed up
Railing sketches should be made up of multiple lines.  The line sections over the stairs are the sloping portion and are set to slope.  The portion over the landing is set to flat.  Somehow, you modified your sketch and have one railing form start to end.  Edit th sketch and break the line into three segments then see what happens.
You will need to learn how far past the last riser you will need the joint to be in order to have your railing all at the same height.  For that ... you need to play with it and learn.
Wed, Jun 11, 2008 at 3:56:00 PM | My Stairs are Messed up
relliot
Alright, thanks I'll try that.  Our tech guy here thinks I need to create one of the landings as a seperate floor, but that would take time I don't really have to spare.  I'll try your idea.  Thanks for the help.
Wrapping stairs
Thu, Aug 12, 2010 at 5:27:03 PM
Handrails at Curved Stairs
Mon, Sep 1, 2008 at 1:43:05 PM
stairs not dotted above
Fri, Feb 17, 2012 at 1:44:47 PM
Spiral Stairs around a Central Post
Sat, Apr 16, 2011 at 9:27:30 AM
Help with stairs
Fri, May 4, 2018 at 7:33:00 AM
Page generation time: 4.5044
