119 Users Online (116 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Systems >> Technical Support >> MEP and slopes
Wed, Jun 11, 2008 at 9:42:48 AM | MEP and slopes
krisbchreme
Has anyone done a job with slopes that cut through work planes such as a parking garage? It appears to work fine for architectural, but it's been a nightmare for us MEP guys. I'm showing light fixtures on different levels/floors in 3D just to get them to show up correctly in plan view. It's not just fixtures; it's devices as well. In order to show a receptacle at 18", I might have to place it on the level below. In order to show a fire alarm strobe at 80", I might have to place it on the level above. It all depends on where I'm at in the slope of the parking garage and the cut plane. Basically, I've found it to be impossible to show things correctly in both 3D and plan views. Plan view is still what ultimately matters so I ended up having "floating" fixtures and devices. I did what I had to do to make it work for DD, but now we're having to circuit and I'm not sure how this is going to work.
Mechanical and plumbing seem to be having slightly better luck because they don't have as many devices and variables, but they have still had issues. Has anyone dealt with this scenario?
ramps with multi slopes
Thu, Apr 23, 2009 at 12:53:24 PM
revit roof slopes
Tue, May 6, 2014 at 10:19:05 AM
Can individual Objects be bound in Arch then changed in MEP
Thu, Jun 7, 2012 at 1:37:23 PM
Revit MEP or AutoCad MEP
Fri, Oct 14, 2011 at 8:21:49 AM
slab with 2 slopes
Wed, Apr 15, 2015 at 9:22:17 AM
Page generation time: 0.3775
