Forums >> Revit Building >> Technical Support >> Can Not Make cut-out
9 Posts No Rating |
I'm using 09 Revit. I am constructing a geodesic dome. I only had to model 1/5th of it. I created a square roof that I could add bearing heights and then cut out with vertical opening. I completed the construction of the 1/5. I grouped the opening cut and the roof. No matter what I try. example: I can mirror 4 of the 5 panels just fine but when it comes to the last 5th it tells me "CAN'T MAKE CUTOUT". Thank You, Raun Tinklepaugh DWL Architects
Can you put some images here to figure the model?...
9 Posts No Rating |
Here you go! Have Fun!
Where are they?
9 Posts No Rating |
I uploaded the file....
Hi, you can do ti with "Array - Polar"
9 Posts No Rating |
I did that and it tells me the same thing. Can't cut out.... It's only that one piece.. Did it work for you?
Yeah, there is some issues but...
9 Posts No Rating |
9 Posts No Rating |
That as far as I get....
I exported 1 segment to DWG, then imported it back into revit in a Mass Family then did the polar array...
Regards,
Chris.
9 Posts No Rating |
Thank You to all for your suggestions. I actually ended up offsetting the cutline by 1/16. I worked perfectly... Thank You
Can't make a Two Cut - Square rafter cut on a roof |
Fri, Jan 14, 2011 at 6:20:30 PM
make elevation cut line show from diffrent planes |
Thu, Jul 9, 2009 at 2:10:05 PM
is there a way to make walls cut floors? |
Mon, Feb 5, 2007 at 9:39:07 AM
Revit 2014 perpendicular cut at the end of the truss |
Sat, Jun 27, 2015 at 4:39:13 PM
Section cut through the imported dwg file |
Wed, Jun 26, 2013 at 4:00:40 PM
12
