Forums >> Revit Building >> Technical Support >> 3D Model not displaying correctly.
5 Posts No Rating |
My company has just recently jumped into Revit 2009. I hid a section of glazing. When I when to unhide it, the building ceased to display correctly; as if the model were a mix of hidden line, wireframe and shaded-edge. If did this a couple of times, but if I closed out and re-entered Revit the problem corrected itself. Now the problem persists. The model still displays correctly in elevation, section, plan and 3D Views. Does anyone know what the problem is? The attached jpg shows how the model is displaying. Thanks for your help...
You forgot attach the image...
5 Posts No Rating |
Not sure the image did attach the first time. Here you go.
Hi, go to the "Options" and uncheck "OPEN-GL", restart Revit and try...
5 Posts No Rating |
Unfortunately, I have been running with Open-GL disabled.
It's in the same?
5 Posts No Rating |
I started the model with Open-GL disabled. I tried it with it active before, but it didn't help. I currently have it inactive (unchecked). Thanks for your continued help.
When you put OPEN_GL inactive you restart Revit? if so, what carecteristics of your machine?
in roof you have a flat element, pick them, with the right button select "Override Graphics in view - By element" and check if it's "Transparent"...
5 Posts No Rating |
Typhoon, Thanks for your assistance. As far as we can tell it is a glitch with the ViewCube. If you click on the top view, then on the Home button the model regenerates immediately. We tried it several times with the same result. No other combinations of view minipulation seemed to work. Truth be told, our AutoCad manager with little Revit background figured it out. A fact, he was all to happy to point out. Thanks again for your assistance.
2015 CURVED WALLS NOT DISPLAYING IN REVIT CORRECTLY |
Fri, May 6, 2016 at 9:21:21 AM
Model elements not displaying correctly |
Thu, Oct 27, 2016 at 10:41:35 AM
Thickened Slab Edge not displaying correctly. |
Tue, Sep 2, 2008 at 9:50:38 PM
windows in elevation and 3d not displaying correctly |
Thu, Oct 6, 2016 at 9:15:32 AM
Doors displaying as gray in Shading with Edges |
Thu, Aug 6, 2009 at 3:46:43 PM
Members: | 2100905 | Objects: | 23171 | Forum Posts: | 152292 | Job Listings: | 3 |
