48 Users Online (46 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Community >> Newbies >> hatch and component troubles
Tue, Jun 10, 2008 at 12:22:56 PM | hatch and component troubles
pancho
I have been experiencing two problems:
1.    I imported hatch from cad works fine in release 08 but in 2009 the hatch pattern  wont print
2.    I created some electrical components (douplex outlet, data,tel,….etc) in the past they worked fine,I just started working on a new project and I drop the components in plan and they become invisible.they are selectable but they are not visible in plan.how ever I went to the roof and I can see them there how can I fix this.
Tue, Jun 10, 2008 at 12:59:47 PM | hatch and component troubles
4 Stars: 203 Votes
Hi, about "Hatchs" i don't know, i think they change something about this, try: http://www.revitup.co.za/main/page_home_home.html
http://www.revitzone.com/
About the "Electric components, you must edit the family and check the "Visibility options in plan"
Tue, Jun 10, 2008 at 1:36:10 PM | hatch and component troubles
For the components - This sounds like a visibility issue.... something is different.  Are you sure they are within the view range?  Change their elevation and see what happens.  Other things to check include is the category hidden? Are they in another workset that is not on?
Tue, Jun 10, 2008 at 3:28:26 PM | hatch and component troubles
pancho
I HAVE TRIED TO CHECK THOSE THINGS U MENTIONED. I CHECKED MY ELEVATIONS AND THE COMPONENTS APPEAR CORRECTLY. I NOTICED MY ELEVATION MARKERS ARE NOW SHOWING ON MY FLOOR AND ROOF? WHAT GIVES?
Edited on: Tue, Jun 10, 2008 at 3:31:02 PM
Tue, Jun 10, 2008 at 4:05:08 PM | hatch and component troubles
These are visibility issues.  Check your view range in the plans..... set it as high as you can - turn on everything in VG in both model elements and annotations.
When I said check your elevation, I meant to check the elevation the element was inserted at.  Make sure it is not covered by another item like a counter.
Content hatch - rotate with component
Mon, Apr 11, 2011 at 10:22:42 PM
Vertical Plywood Hatch Pattern [ 1 2 ]
Mon, Aug 27, 2012 at 4:04:31 PM
17
HATCH 22- REVIT MODEL HATCH
Fri, May 8, 2015 at 3:01:05 AM
R2019: Can I adjust hatch along the element?
Tue, Feb 4, 2020 at 1:53:29 PM
Can I change Structural member hatch scale, rotation??
Thu, Jan 26, 2012 at 6:18:19 AM
Page generation time: 7.7207
