48 Users Online (46 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Tips & Tricks >> Cut-Away View
Tue, Jun 10, 2008 at 12:10:55 PM | Cut-Away View
michael91077
4.5 Stars: 2 Votes
I am working in RAC 2009, and working on a floor framing plan for a residential project, and would like to be able to re-produce this cut away view sh2owing the different materials in the framing, like in the CAD example below. has anyone done this, or does anyone know if this is possible in Revit. see the PDF example below. Thanks.
Tue, Jun 10, 2008 at 1:39:53 PM | Cut-Away View
Check out your help under "orient".
Also check out the forum archives using the same term.  That is where I found this thread.
http://www.revitcity.com/forums.php?action=viewthread&thread_id=374
Tue, Jun 10, 2008 at 3:13:25 PM | Cut-Away View
michael91077
4.5 Stars: 2 Votes
acutally, i got the answer from the Augi forum. since it is not in 3D, just in plan, I could do a filled region over top of the structural joists and show it that way.
window does not get cut in plan view.
Tue, Jul 12, 2011 at 10:37:21 AM
Revit Architecture 2012 - Section shows view from behind cut line
Thu, Jan 10, 2013 at 12:38:21 PM
Model view section cut refer to a drafting view
Wed, Nov 13, 2019 at 5:44:09 AM
Plan view view range
Fri, Nov 2, 2018 at 6:59:28 PM
Cut Geometry shows in 3D and Plan but not in Section?
Fri, Nov 30, 2012 at 1:44:31 PM
Page generation time: 0.9758
