60 Users Online (59 Members):
Forums >> Revit Building >> Technical Support >> slice massing object?
13 Posts No Rating |
Is it possible to slice massing object like in AutoCAD? So I can divide an object into two parts without missing it's size. I couldn't use void tools because it will reduce the size, right?
Sorry no real automatic way of doing this that i know of.
Copy and paste aligned same place, then edit the sketch of both elements to be the reflected halfs of each other...
Or draw half and mirror it over the centre...
HTH.
Cutting a Massing Cube with a slice in the corner |
Sat, May 7, 2011 at 5:07:10 AM
Roof massing |
Wed, Apr 29, 2009 at 10:51:01 PM
Trimming Walls to a slope |
Fri, Feb 24, 2006 at 1:27:41 PM
solid object from 3D dwg |
Thu, Apr 16, 2009 at 5:17:17 AM
massing |
Fri, Feb 27, 2009 at 3:52:43 PM
13
Members: | 2042244 | Objects: | 23026 | Forum Posts: | 152217 | Job Listings: | 3 |
