73 Users Online (71 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> PC SPEC SUITABLE FOR
Mon, Jun 9, 2008 at 9:12:23 PM | PC SPEC SUITABLE FOR
robert
I am getting ready for a new pc.
And would value the opinion of revit users in relation to the latest Revit
 The proposed speci is as follows :
 MB  GIGABYTE  GA-EP35C-DS3R
 CPU Q9450
 RAM 4/2GIG KINGSTON DDR2
 POWER  COOLER MATER 700W
 HD 500GIG WD sata 7200 (C DRIVE SOFTWARE)
 HD 500GIG WD  sata 7200 (D DRIVE DATA)
 VISTA BUSINESS ULTIMATE  (Vista will give me max ram)
 GRAPHICS CARD:
GIGABYTE 9600 GT 512 mb ram OR
ASUS 9600 GT  1 gig ddr3  ram
 DVD 20X
MONITOR:
I have a glossy screen on my laptop which is great for presentations
but would a matt screen be better to work on?
thanks
Robert
Mon, Jun 9, 2008 at 9:36:51 PM | PC SPEC SUITABLE FOR
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Unless you plan on running a lot programs simultaneously OR doing a lot of rendering the quad core is overkill.  Revit will only make use of 1 of those cores running at 2.66GHz.  As such I would go for a faster core 2 duo like the E8500...
But as I said previously if you are doing a lot of rendering it could be worth it.
8GB Ram definitely.
I'd go a smaller HDD for windows.   250GB is plenty for program installations.  And then have a Terabyte HDD for data.
Vista will only give you the ability to use more than 3GB RAM if you purchase the 64 bit version...
With the Monitor, its what ever you like better.  I've had both and you don't really notice much difference.  You didn't mention monitor size either...  I prefer 26"-30"
Regards,
Chris.
Mon, Jun 9, 2008 at 10:14:26 PM | PC SPEC SUITABLE FOR
robert
Tanks mr spot for your promt reply,
i was hoping you respond.
cpu:
i do not do a lot of actual rendering,
but i do a lot shop interiors with a lot of detail, does this still require a lot of grunt
although i try to avoid autocad most of the time i still have two drawings open just to reference.
i thought 1 core would be used for revit one,one for autocadand the others for all the other stuf running in the background that the thought behind the quad core.
vista:
yes definetly 64 bit
monitor:
someone suggested 2 / 22" monitors as they are relative cheap now just a fraction more than one 24"
i did try two monitors but did not fall in love with it
i am very keen hear your opinion in regard to the graphics cards i am considering
would it be a good idea to leave the backdoor open for a extra sli card by having a motherboard which can handle
same?
what about on board ram on these card, the moor the better?
hd:
i originally selected 250gig for operating systems 500 gig was not must dearer
i think your idea is better 250gig plus 1 terra
thanks again,
robert
Tue, Jun 10, 2008 at 7:13:40 AM | PC SPEC SUITABLE FOR
robert
some more question for mr spot:
what are the resolutions and responce times of the 26" and the 30"
monitors you have in your office?
i had a comment from a autocad user about my proposed graphics card being somewhat light on,
but a believe you feel revit does not need much in regards to graphics cards?
thanks
robert
Tue, Jun 10, 2008 at 9:00:02 PM | PC SPEC SUITABLE FOR
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Hmm lots of questions Smile
  1. If you aren't doing much rendering then 2 faster processors would be my choice. I have 2 cores and generally Revit eats one of those and the background apps (Photoshop, AutoCAD 2009, Outlook, Filemaker, Windows) seem to be fine on their core (it generally sits on about 30% usage)
  2. Regarding Monitors.  Currently I have a dual setup of a 30" + 19" in portrait, which i find great.  I don't really see a point in having two large monitors, my portrait monitor i use for Internet, Filemaker & Explorer.
  3. The response time of the 30" is 5ms, but it really doesn't come into play in CAD.  The only reason you need fast response time is for video or games...
  4. Regarding Video Card, it is always a distant 3rd to CPU and RAM.  What you are proposing is more than capable of meeting the demands of Revit for at least a couple of years.  As long as it has dual DVI output your fine.
HTH.
Regards,
Chris.
Tue, Jun 10, 2008 at 9:53:17 PM | PC SPEC SUITABLE FOR
robert
thanks Mr Spot,
i noticed that the resolution on the 24" & 26" monitors does not go over 1920x1200.
also text on the glossy screens, shows very sharp compared to a fuzzy text on the same size
matt screen
thanks and cheers
robert.
e-Spec evaluation
Fri, Jan 4, 2013 at 9:56:01 AM
What is the true Minimum machine spec for a BIM Engineer?
Wed, Jul 2, 2014 at 8:32:51 AM
Revit and Sat file importing pc spec?
Mon, Mar 15, 2010 at 11:55:15 AM
Master Spec and Double Skin walls
Wed, Dec 28, 2016 at 5:40:21 PM
Quesiton about Computer spec. for REVIT
Wed, Sep 19, 2007 at 5:39:34 AM
Page generation time: 0.2045
