52 Users Online (50 Members):
Forums >> Revit Building >> Technical Support >> Edited profiles in section do not appear in callouts
5 Posts No Rating |
Hi, I was wondering if anyone has encountered the same problem I'm having with callouts. I've edited a section with "edit cut profile" followed by a call out on a portion of the section. The edited work I've done does not show in the call out detail. Help...... Thanks
Edit cut profile is a 2d process and like all 2d elements, it is view specific. You can edit your cut-profile, copy the line work to your clipboard, then goto the detail view and edit the component there and paste in your work.
5 Posts No Rating |
Hey WWhub, Thanks for the comment.....I'll givie it a try!
multiple section callouts |
Wed, Jun 4, 2008 at 9:04:18 AM
Section Callouts Dissapear w/Level Change |
Tue, Aug 19, 2008 at 1:45:27 PM
Section Callouts in Elevation |
Thu, Nov 1, 2007 at 10:54:10 AM
Are Callouts Vew Specific? |
Wed, May 12, 2010 at 3:56:06 PM
HELP! callouts are not visible!! |
Sat, Feb 16, 2008 at 12:17:21 PM
Members: | 2022246 | Objects: | 22974 | Forum Posts: | 152201 | Job Listings: | 3 |
