35 Users Online (34 Members):
Forums >> Community >> Newbies >> Drawing conventions
16 Posts No Rating |
Hello all, I am a Noob with Revit and the community... First of all I have Revit 2009. I found out that the drawing conventions are very American and not European... As I am trained in European conventions, I would like to use them...some examples: - when I have a shaft like an elevator or service core, we add a cross to show that the space is running vertical through the building - when there is a structure cantilevering on the other floor on top we use a hashed line to show it is there... This is all the problem in plan view Thanks for your help
Hi and welcome in Revit World, i also use European conventions but do you made a question? what's the problem with the two examples you post? You can drew like do you want, you can use and abuse from Revit capacities...so?
hmmm thanks for the fast reply I learn that Revit makes a lot of automatic decisions, so I would like to use them... Q1: How can I show the lines in plan that show the lines above the head (which are invisible, dashed) q2: how can I show in plan that a shaft or a service core has a cross? Thank you
Hi again, in plan go VP and you can change the elevation of "cut plane" the "Top and Bottom level", but you also have in left pop menu a "Drafting" witch you can draw and create hatch and different kind of lines, if you have difficultes you also have the HELP menu....
parameter naming conventions |
Thu, Apr 2, 2015 at 8:44:13 PM
Naming Conventions |
Tue, Jun 7, 2011 at 5:45:11 AM
Revit 2009 Naming Conventions for Detail Titles |
Fri, Aug 26, 2011 at 11:25:41 AM
Revit 2009 Schedules |
Mon, Jul 25, 2011 at 10:22:50 AM
Family Naming Guideline |
Thu, Dec 11, 2008 at 5:42:49 AM
Members: | 2022388 | Objects: | 22974 | Forum Posts: | 152201 | Job Listings: | 3 |
