Forums >> Revit Building >> Technical Support >> How to Unfold Window???
I have a corner window(or Curved Wall) in my project, but I want to represent it as unfolded in the Schedules (or Legends). Thanks Pavan Reddy
Pavan Reddy
Revit Manager
Intelligence is not always knowing the answers, it's always asking the questions. |
78 Posts No Rating |
Did you ever get an answer to this? I am currently trying to do the exact same thing
No, I didn't get. You can palce 2 elevations on either sides and place 2 elvations side by side or draft it.
Pavan Reddy
Revit Manager
If its a curved wall you must draft it as a drafting view, then place an elevation and link to it. If its a series if angled walls, you can splice mulitple elevation views together, then hide all but one elevation call out.
The window I am trying to show is multi angled (like the letter Z, except all angles are 90 degrees). However, in the window legend, I am only able to show front and rear elevations. Is there a way to add a side elevation as well? Thanks
How do I unfold and elevation with accuracy? |
Thu, Sep 4, 2008 at 6:52:42 PM
Using Revit to Detail Complex Curved Geometry (Rhino/Inventor Unfold Command) |
Wed, Apr 17, 2013 at 9:16:36 AM
Can Revit Unfold 3d objects for 2D CNC processing? |
Fri, Oct 19, 2012 at 10:41:12 AM
Window sashes with different window numbers in the window schedule |
Tue, Mar 19, 2024 at 11:49:53 AM
Window Legends-showing nested components |
Thu, Mar 20, 2008 at 4:20:36 PM
Members: | 2098828 | Objects: | 23170 | Forum Posts: | 152292 | Job Listings: | 3 |
