168 Users Online (167 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Revit 2009: detailings: tag that list all wall's materials
Sun, Jun 8, 2008 at 5:45:54 PM | Revit 2009: detailings: tag that list all wall's materials
Asidie
Hi all,
I'm learning Revit and, thanks to all of you, i'm getting good at it. I want to know: if you do a callout view of a wall, is it possible to add a tag to the wall that list all the materials of the wall, from the outside to the inside or inverse?
Also, when in a detail view, i added materials tags to the drawing, to walls and floors. I Can't tag detail componnent.
Also, if I had materials tags to a wall section, if I move the wall, the tags does'nt follow the wall. They are unconnected.
Thanks to all,
Math.
Mon, Jun 9, 2008 at 10:07:50 AM | Revit 2009: detailings: tag that list all wall's materials
Hence
1 Stars: 1 Votes
I'm not sure about making a tag that will read the materials, but what we have done at our office is name our walls based on the wall construction [ie: exterior finish,air space, sheathing, stud, interior finish]. We have abbreviations for each of the names of the wall so that the name isn't a mile long, but this helps to organize or walls so we know exactly what we are putting down.  Also you can make a wall tag that will read the wall type, that will read the name of the wall that will list all the materials that you choose to have in the name of the wall type.  However this will only work on basic wall types, wall tag do not work very well for stacked walls [at least this is true for RA2008, my firm is taking its time updating to 2009 Sad
I hope this helps
Mon, Oct 12, 2009 at 7:47:26 AM | Revit 2009: detailings: tag that list all wall's materials
leighton
That's great to know. I'm a newbie and i'm still getting the hang of things with Revit. Hopefully, i'll become as good as you. Good luck.
Regards,Leighton[URL=http://placementfinancier.net/category/placement-financier]Placement financier[/URL]
Any way to tag all of the layers of a wall/roof with a single tag?
Tue, Apr 9, 2013 at 4:22:51 PM
Material tag and doors
Mon, May 29, 2006 at 5:04:08 PM
Another ODBC question
Thu, Sep 25, 2008 at 12:35:25 AM
Materials List
Tue, Feb 13, 2007 at 2:04:41 PM
REVIT 2009 - MATERIALS
Tue, May 5, 2009 at 10:01:41 AM
13
Page generation time: 4.4060
