111 Users Online (110 Members):
Forums >> Revit Building >> Technical Support >> stair stringer endings
2 Posts No Rating |
Does anyone know how to modify the stair properties so that the topmost stair tread depth is four inches wider ( than the normative tread depth of the flight) as it attaches to the edge of a floor slab? also, the (closed) stringers would have to be 'trimmed' to level off at two inches above the slab as they also attach to the floor slab. i can't figure out how to get the stringer to extend beyond the last tread. is any of this possible with the revitized stair or am i better off building the 'ends' of the staircases as separate elements that attach to the revit stair run? if you can help, eternally indebted.
Have you checked out the Autodesk Revit Stair White papers crib sheet...? (attached)
This should help to explain what the different options do...
As for having a different tread thickness for the top tread, this is currently not possible. You would need to model it as a separate element.
HTH.
Monolithic Stair with Stringer |
Wed, Aug 5, 2009 at 10:43:24 AM
Stair Stringer Question |
Fri, Jul 28, 2017 at 4:01:08 PM
Stair Stringer Offset |
Wed, Jul 15, 2009 at 2:20:56 PM
Stair stringer offset (2015) |
Mon, Sep 14, 2015 at 9:19:19 AM
Stair Stringer Cutting Stair Treads and Risers See Image |
Thu, Jun 5, 2014 at 7:59:38 AM
Members: | 2017341 | Objects: | 22947 | Forum Posts: | 152212 | Job Listings: | 3 |
