63 Users Online (62 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Systems >> Technical Support >> 3d dim
Fri, Jun 6, 2008 at 6:27:43 PM | 3d dim
soazvw
1 Stars: 1 Votes
im going crazy....is there any way to put dims in a 3d view. it will only dim on the ground plane. i cant dim hights!!! thanx for the help.
 -Allen
Fri, Jun 6, 2008 at 9:25:50 PM | 3d dim
dianajohn
You need to select the plane that you are dimensioning
Best of Luck John A
Mon, Jun 16, 2008 at 3:55:39 PM | 3d dim
jmskennedy
Can you explain how you select the plane.  I can hit tab and cycle through the planes that I want to dimension in the view but it still forces them to snap on the base plane.  Is there a way to define the plane that the dimension is located in or do you have to use a reference plane?
It sure seems like this should be intuitive but I can't figure it out.
Thanks.
James
Mon, Jun 16, 2008 at 4:08:31 PM | 3d dim
4 Stars: 203 Votes
Hi JMSKENNEDY it's very simple to define the plane where you want to work, in this case dimension the 3D object see the video: http://screencast.com/t/KXUFBsLKf0O
Mon, Jun 16, 2008 at 4:09:17 PM | 3d dim
jmskennedy
Nevermind.  I figured it out.  You just need to choose the work plane before you place the dimensions.  Much easier than I made it out to be.
Diminsion under dim line
Fri, May 18, 2007 at 10:10:31 AM
Settings for stringer
Thu, Oct 3, 2013 at 7:53:56 AM
Temp Dim's are too small
Mon, Jul 30, 2007 at 10:36:06 PM
Adding Dim Width parameter
Mon, Apr 11, 2005 at 9:20:50 PM
how to add a "dim" with having the length
Wed, Oct 12, 2005 at 1:18:56 PM
Page generation time: 0.8167
