68 Users Online (67 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> SELECT ALL INSTANCES
Fri, Jun 6, 2008 at 10:30:11 AM | SELECT ALL INSTANCES
clinard
I've noticed that when you select all instances of text, it selects the same type text accross the entire project. How do you select all instance of text on the current drawing your working on??
Fri, Jun 6, 2008 at 10:54:53 AM | SELECT ALL INSTANCES
clinard
nevermind figured it out. had to drag a box and highlight everything on the drawing, select filter then check just the text box.
select all instances??
Fri, Feb 6, 2009 at 7:36:05 AM
Find objects in views using "Select All Instances in View"
Tue, Sep 3, 2024 at 5:10:22 AM
Select All Instances does not actually show all instances
Thu, Mar 28, 2013 at 1:38:38 PM
Select all instances by view
Mon, Apr 26, 2010 at 7:11:09 PM
Finding "Select All Instances in Project"
Fri, Oct 30, 2015 at 12:42:40 PM
Page generation time: 2.0810
