39 Users Online (38 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Structure >> Technical Support >> Title Numbering
Fri, Jun 6, 2008 at 5:55:35 AM | Title Numbering
MartinGT
1 Stars: 1 Votes
Is there a way of turning off the title number bubble on plans?
I have a foundation plan and I have put it on a title block.  It has numbered it one, and then I have sections that go in sequence from that, 2,3 etc.  Now, I want the Plan to ahve no numbering and re number the sections
How can this be done?
TIA
Fri, Jun 6, 2008 at 9:07:01 AM | Title Numbering
JAMESHGRIMES
JAMESHGRIMES Avatar
4.5 Stars: 10 Votes
You will need to create a new View Title family that does not have the number. Open your current and saveas, then erase the number and any other lines you do not want.
You will then load the new View title family into the project and go to a Sheet view. Select the viewport you want to change and go to properties and make a new Viewport type and apply the new View title to that viewport type. You can then use the same view port type on any view where you don't want the number to show.
Fri, Jun 6, 2008 at 9:42:51 AM | Title Numbering
MartinGT
1 Stars: 1 Votes
Ah Thanks for that
Now my problem is changing the number on the section marker?  How do I change it for example from a 5 to a 2?
I have clicked on it and changed it but it says I cant as its not unique or its in use, yet I cant see another section with the same number?
Fri, Jun 6, 2008 at 11:26:26 AM | Title Numbering
JAMESHGRIMES
JAMESHGRIMES Avatar
4.5 Stars: 10 Votes
The issue here is that even if the view is not physically numbered it still has to "number" to keep track of it. What I would suggest is to click on the view with no number and go to properties and in the number field type a number that you are sure you will never use. This will allow revit to track the detail and also allow you to renumber the other details as desired.
How to change view title numbering from 1 to 01
Thu, Oct 20, 2022 at 2:05:51 PM
Numbering Sections
Wed, Jul 15, 2015 at 1:49:32 PM
Stair numbering
Tue, Feb 27, 2018 at 4:34:51 PM
Revision Numbering
Thu, Jun 18, 2015 at 2:33:41 AM
Door tag numbering / room tag numbering
Wed, Nov 2, 2005 at 5:08:50 PM
Page generation time: 0.9402
