92 Users Online (91 Members):
Forums >> Community >> Newbies >> Automatically Render to a new location other than internal hard drive?
![4.5 Stars: 2 Votes](/images/stars_4.5.gif) |
I am currently using Revit 2009 on a apple computer which is partitioned to have both vista and mac os. Currently many of my renderings are too large to render to my vista partition, as I did not give it enough space when I partitioned the drives. I would like to avoid uninstalling vista and re-partitioning at the most as it willl cause a huge delay in my thesis project. Is there a way to set the settings for when Revit renders to automatically save to an external hardrive, or a different location other than my "pc". Also I was not quite sure where to find this location. Thanks so much for your help!!!
![Mr Spot Avatar](user_avatar/1073.jpg)
![4.5 Stars: 93 Votes](/images/stars_4.5.gif) |
You can only control when the image is exported to, you cannot change its default rendering location...
Regards,
Chris.
I believe you can change the tmp. variable... I am testing to see if this works out. Do you if there is a way to set batch settings as in have several render at the same time, or at least one after another?
Not enough hard drive space |
Sat, Jan 8, 2011 at 6:09:16 AM
11
Local Files and Reformatting my Hard Drive |
Thu, Jun 7, 2012 at 8:24:39 AM
Render Internal Lighting Issue |
Sun, Nov 7, 2010 at 8:04:47 PM
Are solid State drives ok for Revit Architecture? |
Tue, Nov 8, 2011 at 8:10:51 PM
Pattern file location on drive |
Wed, Mar 18, 2015 at 12:26:06 PM
Members: | 2017187 | Objects: | 22947 | Forum Posts: | 152212 | Job Listings: | 3 |
