87 Users Online (85 Members):
Forums >> Revit Structure >> Technical Support >> TOP OF STEEL / RAM IMPORT
7 Posts No Rating |
REVIT STRUCTURE 2008 WHEN INPORTING A RAM (*.RSS) MODEL INTO A 'CLEAN' REVIT DRAWING THE 'TOP OF STEEL' DO NOT ALIGN. (GIRDERS ARE W18x AND JST ARE W12x) I AM NOT SURE WHERE THE PROBLEM IS OCCURING - A RAM SETTING OR A REVIT SETTING. THE REVIT ANALYTICAL MODEL PICKS THE CENTEROF EACH BEAM AND THOSE ARE ALIGNED. IN THE REVIT 'USERS GUIDE' PAGE 288 SAYS THAT IF DEFAULT POSITION OF THE CREATION PLANE IS A LEVEL THE BEAM'S CREATION PLANE IS AT THAT LEVEL. HOW DO YOU CHANGE THE DEFAULT ANALYTICAL MODEL POSTION AT A LEVEL TO BE TOP AND CENTER OF BEAM. OR ANY OTHER SUGGESTIONS WOULD BE APPRECIATED.. THANKS, M-
![Mr Spot Avatar](user_avatar/1073.jpg)
![4.5 Stars: 93 Votes](/images/stars_4.5.gif) |
Hi Mark, I actually haven't used Revit Structure myself... I would suggest you post this question on the AUGI forums if you haven't already as there are a lot more revit structure users on those forums... HTH.
Regards,
Chris.
Revit Arch importing RAM steel files |
Mon, Jul 16, 2007 at 9:01:19 AM
flat channel top of steel |
Wed, Oct 26, 2011 at 2:13:55 PM
Import to RAM Structural System |
Thu, Aug 23, 2007 at 5:10:06 PM
Aligning top of column to top of beams that are set out by bottom of steel |
Thu, Dec 12, 2013 at 12:35:41 PM
Ram-revit link problem |
Wed, Oct 13, 2010 at 11:03:41 AM
Members: | 2017166 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
