71 Users Online (68 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> How do I print a Render image on a titleblock??
Thu, Jun 5, 2008 at 2:34:19 AM | How do I print a Render image on a titleblock??
ellenor
Hello I am a new user of Revit
Can annyone help me please.
Thanx Ronelle
Thu, Jun 5, 2008 at 6:38:30 AM | How do I print a Render image on a titleblock??
I assume you mean a sheet titleblock and not the title page.
After you create your rendering, export the image to an appropriate file tiff/jpeg.  (I prefer jpeg)  NOTE: - You do not need to capture the image.  Capture stores the image in the project file and will make the file bigger.  You want to save the image in an external file.
Now, open your titleblock sheet family in the family editor and insert the image.
Load the sheet back into your project.
Thu, Jun 19, 2008 at 9:38:00 AM | How do I print a Render image on a titleblock??
ellenor
Thanks, that helped.
Thu, Mar 22, 2012 at 3:09:18 PM | How do I print a Render image on a titleblock??
batakarojo
Hello, i had the same problem, i fixed:
In the images properties while editing titleblock, in "Draw Layer" chose "Foreground".
Good Luck!!
Greeting from El Salvador.
jpg image won't show when I print titleblock
Fri, Feb 6, 2009 at 2:51:54 PM
Image Missing From Titleblock Once Printed
Wed, Apr 11, 2012 at 8:57:21 PM
Titleblock resized after export
Fri, Feb 7, 2014 at 8:40:40 AM
Printing Images on my TitleBlock..???
Wed, Feb 16, 2011 at 10:24:55 AM
Print views to scale on a sheet without a titleblock
Thu, Nov 12, 2009 at 7:02:52 AM
Page generation time: 0.5882
