Forums >> General Discussion >> Revit Project Management >> Modeling Process2
5 Posts No Rating |
I am very new to Revit and I am teaching myself the program. For those of you who are experts in the program what is the correct way to setup a BIM model? My guess is: 1. Elevation tags for floors 2. Grid lines for columns (if you have any) 3.Foundation, Columns and Floor slabs for all floors 4. Shear walls or any other structural members 5. Exterior walls 6. Interior walls 7. Windows and doors 8. Stairs 9. Bathrooms and Kitchens 10. M.E.P. 11. and then you get into the Details I know this list can be done in any number of ways but would you do this in a floor by floor basis or would you do every category indendantly like shown?
Are you asking about worksets? If so, then this is way too complicated for most projects. We usually like to do the exterior skin on one workset so that we can isolate that in work that only requires an exterior image. In this way, you can minimally load several projects for a combined site model. REVIT automatically creates shared levels and grids and we use that in the same way as created. We may create an interior workset for our interiors department. Other than that, Workset 1 - also automatic - is usually our only otrher workset on most projects.
Edited on: Thu, Jun 5, 2008 at 6:45:44 AM
"For those of you who are experts in the program what is the correct way to setup a BIM model?" that is the next bump in the road for BIM. Contractors are now starting to call Architectural BIM models, throw-away models, because most are not modeled to the way that they feel it should be done for there purposes. i think in the near future you will have plenty info to help you answer that question. in the mean time i aggree with WWHub, the less complicated the better. after each project this is something that you wiil adjust until you develope something that works best for your workflow. there are organizations working on a set of standards for BIM. i hope this will lessen to the throw-away model trend. i for one plan on adopting those those standards. HTH
When we use worksets we break it down by the "6 S's" Site - topo, plants, parking etc... Strucure - Foundations and any hidden structure Shell - Anything that will be seen in elevation that is strictly building realated (not site) Seperation - Interior walls, floors, stairs Systems - Plumbing, HVAC, any special systems Stuff - Casework, appliances, furnature, etc...
Modeling Process |
Wed, Jun 4, 2008 at 7:37:13 PM
Modeling a family outside of Revit |
Mon, Dec 19, 2005 at 11:39:35 PM
Show phases of modeling |
Tue, May 9, 2017 at 4:13:37 PM
how to modeling this project? |
Sat, May 17, 2014 at 3:20:40 AM
Revit modeling services provided [ 1 2 ] |
Sat, Jun 27, 2009 at 3:13:56 AM
16
Members: | 2115946 | Objects: | 23193 | Forum Posts: | 152301 | Job Listings: | 3 |
