95 Users Online (94 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> General Discussion >> Revit Project Management >> Adding "Suffix" text to dimension strings in 2009
Tue, Jun 3, 2008 at 11:35:09 PM | Adding "Suffix" text to dimension strings in 2009
azcop
Can anyone help me please!
 Our company standard when dimensioning plans is to represent the room name in the dimension string (i.e. "3500 Bed 2"Winking. To this point in time we have been able to do this within "Element Properties" under the text category "Suffix".
Now that we have installed Revit Architecture 2009 I've noticed this option is now unavailable. Does anybody know if this can still be done without the tedious job of doing it in text alongside the dimension??? (this is very time consuming and does not centre correctly).
Any help would be greatly appreciated................. can't understand why Autodesk would remove features from their product.
Many thanks.
Wed, Jun 4, 2008 at 10:24:35 AM | Adding "Suffix" text to dimension strings in 2009
mlohr
mlohr Avatar
HI!  ...if you select the dimension string and then select the dimension where you want the text to appear, a dialog box with options for adding text will pop-up...that's how we've been doing it...
Wed, Jun 4, 2008 at 7:29:29 PM | Adding "Suffix" text to dimension strings in 2009
azcop
WOO-WHOOOOOO!!!!!!!!!!!
You my friend ARE A BLOODY LEGEND!!!!!!!!
I knew it would be something simple, as it turned out I'm the simple one. THANKS ONCE AGAIN BUDDY! YOU'VE MADE MY DAY!
Stacked Dimension Text (Prefix/Suffix)
Fri, Jan 27, 2006 at 6:21:27 AM
Inserting text under dimension in string dimension
Thu, Apr 2, 2009 at 9:47:52 AM
Detail Custom Text Change
Thu, Oct 23, 2008 at 11:59:07 AM
text stacked and suffix in dimension style_ possible?
Mon, Jul 9, 2012 at 12:57:18 PM
Dimension strings not adding up to the total length dimension string (2017)
Fri, Mar 23, 2018 at 1:33:59 AM
Page generation time: 1.9579
