90 Users Online (88 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> General Discussion >> Revit Project Management >> Curtain Wall Elevations
Tue, Jun 3, 2008 at 4:15:12 PM | Curtain Wall Elevations
andymeyer50
I am elevating all of our curtain walls throughout our project and finding that when I place those views on our plot sheet, once I activate the view and try to edit the profile of the curtain wall it cannot be done in this view. The only way I can edit the profile is to go to the exterior building elevation. I can't even select the center lines of mullions to reposition them in the interior elevation view. Has anyone had this problem? I have had this happen numerous times in the past but this project every frame is that way it seems like. Thanks,Andy
Tue, Jun 3, 2008 at 5:44:54 PM | Curtain Wall Elevations
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
I haven't experienced this, are you sure you just don't have an item turned off that you need on to edit the curtain wall. Such as "Walls" or "Lines" or "Curtain System"?
Try turning on "Reveal Hidden Elements" first and then try making the change...
Regards,
Chris.
Curtain Wall Panel to Curtain Wall Door
Mon, Jun 23, 2014 at 9:32:12 AM
Curtain wall not cutting through moulding
Thu, Oct 22, 2015 at 2:53:45 PM
Splitting a curtain wall to change the type of wall it is
Thu, Aug 6, 2009 at 12:46:43 AM
Can't Put Curtain Wall Inside Stacked Wall??????? Help Needed
Thu, Jan 24, 2013 at 8:06:07 PM
curtain wall
Sat, Jan 10, 2009 at 10:01:36 AM
Page generation time: 3.4982
