104 Users Online (103 Members):
Forums >> Revit Building >> Technical Support >> Editing Time Zone in Revit 2009
3 Posts No Rating |
Hi All, The time zone for my city (Darwin, Australia) in the window 'Manage Place and Location' is wrong. I need to set it to GMT+09:30. Does anyone know how to edit the time zone in revit 2009? It seams that is possible only to edit the values for the Longitude and the Latitude. The time zone value is greyed out. Thanks for your kind consideration.
----------------------------------- Life is more than merely staying alive. |
Hi, you can change this options in the file in revit name: "Sitename.txt", it's in folder "program" in Revit Architectural 2009.
3 Posts No Rating |
Thanks Typhoon for your help but I have already looked at that file (Sitename.txt) and unfortunately it doesn't says anything about Time Zone and how to edit it. Cheers
3 Posts No Rating |
Hi all, Bruce Gow found the solution. In order to activate the time zone drop-down list you need to delete a number from the given latitude and click on the longitude value (or vice versa). After modifying the time zone you can add back again the deleted number from the given latitude (or vice versa). If you just simply replace the given values for the latitude and longitude, the time zone drop-down will not be activated. Ciao.
Zone and spaces |
Thu, Nov 25, 2010 at 8:41:41 PM
Rooms don't automatically assign to Default Zone |
Sun, Jan 11, 2009 at 9:53:10 AM
HOW TO CREATE A NO FLY ZONE |
Wed, Feb 2, 2011 at 9:46:14 AM
Dimension Editing |
Fri, Jan 26, 2007 at 8:03:13 PM
Using/Editing a Family Built in Revit 2009, in Revit 2008... what are my option. |
Tue, Jun 3, 2008 at 3:40:10 AM
Members: | 2017035 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
