35 Users Online (34 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Composite walls -Revit 2008
Mon, Jun 2, 2008 at 9:30:09 PM | Composite walls -Revit 2008
escobar719
Im trying to create diffrent maaterial profiles on a single wall segment as follow:
the base wall is 2" EIFS on mtl stud, there are 3"thick EIFS reveal around the 8' wide x 9' high lap siding insert.
The only work around that I know is to create each segments as different wall family with the different thickness and materials. The problem is that I can not apply the fillet command at the corner edege of the building the different walls.
I tried to use the wall sweep, but I do not know how to create a profile of the 3" thick EIFS with 12 wide piers; I also tried to modify a stacked wall with out success.
Do you have any ideas? will be appreciated
See attach rough sketch, unfortunetally I do not have Revit in my personal computer
Tue, Jun 3, 2008 at 9:04:26 AM | Composite walls -Revit 2008
rkitect
rkitect Avatar
4 Stars: 29 Votes
Will this work? (see attached)
I basically edited teh wall profile to allow for the shape.  This does not make a very clen looking interior wall, but if you were to render the lines would disappear as long as the interior materials were the same.
Tue, Jun 3, 2008 at 10:03:25 AM | Composite walls -Revit 2008
escobar719
thank you, but this is what is look like in elevations and floor plan. I am concentrated on the construction detail of the project.
Fri, Jun 6, 2008 at 8:21:53 PM | Composite walls -Revit 2008
escobar719
I found a solution to my wall problem thank to article about composite walls in revit zone. com
I just want to share this information with whom it may concern
composite panel walls
Fri, Feb 25, 2011 at 1:32:37 PM
composite column
Mon, Oct 16, 2006 at 1:53:30 AM
changing line thickness in composite walls
Wed, Mar 25, 2009 at 7:11:09 AM
Making a Composite Mechanical Roof plan
Mon, Sep 27, 2010 at 4:33:50 PM
Composite decking
Sat, Mar 27, 2010 at 8:43:41 AM
Page generation time: 0.8267
