89 Users Online (88 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> General Discussion >> Wishlist >> Room area intelegance
Mon, Jun 2, 2008 at 6:51:36 PM | Room area intelegance
KennyGee
KennyGee Avatar
3.5 Stars: 3 Votes
Would be nice to have the power to exclude items from calculations. for example columns and some walls.  If the room area calculations could have a filter then you could accurately estimate GLA (Gross lettable area), NLA (net lettable area) and SLA (sellable lettable area)... Otherwise these calculations still need to be computed manually.  This function in Revit is a little disappointing
As Im a newbie, there may be something I missing
Mon, Jun 2, 2008 at 7:12:39 PM | Room area intelegance
KennyGee
KennyGee Avatar
3.5 Stars: 3 Votes
maybe editable handles on the room boundary that can be pushed an pulled
Mon, Jun 2, 2008 at 7:43:20 PM | Room area intelegance
mhans
3 Stars: 10 Votes
Use "non-bounding" properties for items (like column, partition, etc) that you don't want to include. From settings, room and Area setting, you can guide revit on where to take the area (al wall finish, center of core, etc.). You can do formula and calculations on most of your schedules. Discover!
Motto: "No Post left behind"
Mon, Jun 2, 2008 at 7:51:17 PM | Room area intelegance
KennyGee
KennyGee Avatar
3.5 Stars: 3 Votes
Cheers mate, thanks for the reply
Thats great, but in my situation i have columns imbedded in some walls, Once I exclude room bounding I get an error - Room is not in a properly enclosed region......
Is there any other method on incorporating columns into walls???
Mon, Jun 2, 2008 at 8:25:46 PM | Room area intelegance
KennyGee
KennyGee Avatar
3.5 Stars: 3 Votes
Ahh I see. Stupid me
Even though they are instances you can alter the options for each.    Still, the method of measurement states that area calculations engage perimeter columns or piers.
Mon, Jun 2, 2008 at 8:44:48 PM | Room area intelegance
mhans
3 Stars: 10 Votes
Though, cumbersome sometimes, you can use join geometry to join walls & columns, to avoid room improperly enclosed error.
Room tags with area - area not showing up!
Thu, Aug 16, 2007 at 6:54:27 PM
changing the scale of my room and area tags with the scale of my area plan.
Fri, Oct 22, 2010 at 10:38:39 AM
Thu, Jan 15, 2009 at 5:51:21 AM
ROOM AREA VARIES DEPENDING ON THE DISTANCE FROM PROJECT ORIGIN
Thu, Jul 12, 2012 at 8:24:18 AM
Tue, Nov 4, 2008 at 3:48:51 PM
Page generation time: 0.6095
