Forums >> Revit Building >> Technical Support >> Drawing Reference Planes in 3 Dimensions?
6 Posts No Rating |
Revit 2008, I am trying to draw a reference plane in a family for the purpose of a sweep. But the RP needs to be at an angle to the x grid and at an angle to the z grid. Any suggestions????
![3.5 Stars: 11 Votes](/images/stars_3.5.gif) |
try placing in one view and then , change to other view , select previous , and rotate but if its to make a sweep you will might want to to this with a line
Edited on: Mon, Jun 2, 2008 at 9:15:42 AM
"There is no path to peace,
peace is the path."
Mahatma Gandhi.
6 Posts No Rating |
No I have tryed this and it will only allow me to rotate this in one directions. Any other suggestions????
it worked for me in a generic model familie,, i drew the RP in planview , named it, and then rotated it in front view
peace is the path."
Mahatma Gandhi.
6 Posts No Rating |
If i had the origional line drawn down the x axis. I need it rotated in the y dimension , then roated in the z dimensions and then tilted in the x dimension.... Any suggestions????
Hi, use "Reference Lines" to do it, and use the Work plane of that Reference line to rotate in the axis you want...
6 Posts No Rating |
Dafpfy, I opened your model and saw that is was done, when i went and drew reference lines in 3D view it was on a new work plane, but i wasn't able from any view to see where that work plane was drawn or understood how it was created. I still can not get a reference plane or line to rotate in any but one axis... any suggestions.
![3.5 Stars: 7 Votes](/images/stars_3.5.gif) |
two reference lines
okay so i tried this one and the best solution looks like a rotating reference plane with a rotating reference line in it. but its far from perfect.
Listing the Abilities of Reference Planes |
Sun, Sep 9, 2012 at 9:24:07 PM
reference planes |
Wed, May 24, 2006 at 10:19:12 AM
Center Reference Planes....... |
Tue, Jan 30, 2018 at 9:48:46 AM
Locating Reference Planes in Elevation |
Sat, Nov 1, 2008 at 8:05:13 AM
Detail Lines and Reference Planes |
Tue, Sep 20, 2016 at 2:37:46 PM
Members: | 2017117 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
