67 Users Online (65 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Isometric Drawing
Fri, May 30, 2008 at 1:36:22 PM | Isometric Drawing
bbent1
Does Revit 2008 have the capability of drawing in isometric mode like AutoCad?
Fri, May 30, 2008 at 2:11:37 PM | Isometric Drawing
Please learn to use the REVIT help menu.  It really has answers to many questions like this.  Just put in isometric.
Fri, May 30, 2008 at 4:13:09 PM | Isometric Drawing
bbent1
 That is my first approach, but when I enter isometric....Revit help jumps to isolated footing with "isometric"  not anywhere in the "I" section of Help!
Fri, May 30, 2008 at 4:30:21 PM | Isometric Drawing
4 Stars: 202 Votes
Hi, use "F1"....
Mon, Jun 2, 2008 at 9:48:03 AM | Isometric Drawing
LIZARD2806
3.5 Stars: 7 Votes
bbent,
When you go into help, make sure to click the "search" tab, then type in "isometric".  If you are getting an alphabetical list, you are in the index tab of the help file.  The search will return "3D Dynamic View Options".  In there should be your answer.
Isometric Details
Fri, Apr 9, 2010 at 1:31:30 PM
3D / Isometric Detail
Thu, Aug 12, 2004 at 9:37:02 AM
Isometric Dimensions in Drafting Views (details)
Fri, Sep 28, 2012 at 3:13:09 PM
Revit doesn't show Autocad isometric drawings
Thu, Nov 27, 2014 at 10:27:04 AM
ISOMETRIC VIEW, 2009
Tue, Aug 26, 2008 at 3:50:52 AM
Page generation time: 0.7971
