58 Users Online (54 Members):
Forums >> Revit Structure >> Technical Support >> Import Massing to AutoCAD
I tried importing a revit project to autocad, it seems that items that are modeled using Mass is, by default, not included when you transfer it to autocad. Is there a way to do it?
Hi, your question it's unclear because you don't say what version of Revit do yoy use, how do you transfer (dwg, ifc)...
Ensure the Mass is turned on in VV and not just using the "show mass" button. If you still have issues try giving the mass a material.
Regards,
Chris.
Co-Founder | BIM Consultant | Software Designer  B. Arch)
Thanks that solved it! I thought by just "showing mass" is enough. Thanks again Mr. Spot!
import to revit from autocad |
Sun, Mar 31, 2013 at 11:37:12 AM
Autocad Import Problems |
Tue, May 5, 2009 at 1:55:33 PM
Revit Crash when Autocad Site plan Import |
Wed, Jan 7, 2009 at 4:51:26 PM
import shapes form autocad |
Wed, Jan 24, 2007 at 8:50:30 AM
sectioning a dwg import |
Wed, Feb 22, 2006 at 8:07:18 AM
Members: | 2017212 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
