27 Users Online (26 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> What happens to Revit 2009
Thu, May 29, 2008 at 9:06:20 PM | What happens to Revit 2009
bhobho
HI,
Can anyone guide me on the issue below ?
When I use Revit at shading mode I can see model colors but when I use Revit at rendering mode I cant see model colors ( model colors are gray-colored ) ?
 See attached
Thanx in advance
Fri, May 30, 2008 at 2:39:33 AM | What happens to Revit 2009
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Ever Material in Revit has a shaded appearance and a render appearance.  If you don't have a rendering appearance assigned to your material it will render grey...
Regards,
Chris.
Fri, May 30, 2008 at 5:15:48 AM | What happens to Revit 2009
bhobho
Why when I rendering curtain wall  ( colors are black-colored )
 see attached
Fri, May 30, 2008 at 8:30:01 AM | What happens to Revit 2009
4 Stars: 203 Votes
Hi, it's seems like you render with "Artificial lights only", in Rendering settings do choose "Sun only"?
Fri, May 30, 2008 at 5:53:00 PM | What happens to Revit 2009
bhobho
HI again,
Still suffers problems...
see attached
Fri, May 30, 2008 at 8:13:55 PM | What happens to Revit 2009
brettgoodchild
brettgoodchild Avatar
4 Stars: 17 Votes
Did you turn on your daylight portals?
"You cannot escape the responsibility of tomorrow by evading it today. "
                             ~ Abraham Lincoln
Sat, May 31, 2008 at 2:26:02 AM | What happens to Revit 2009
bhobho
 Excuse me What do you mean ... I did not understand
Sat, May 31, 2008 at 3:44:20 AM | What happens to Revit 2009
tawhiri
Have you tried rendering a revit or training file? same outcome?
Sat, May 31, 2008 at 4:10:34 AM | What happens to Revit 2009
4 Stars: 203 Votes
I think your Revit is not insttaled correctly...
Revit MEP 2009 family to be used in Revit Architecture 2009
Fri, Feb 6, 2009 at 8:09:24 AM
Export Mass from Revit 2009 to 3ds Max 2009
Tue, Feb 16, 2010 at 9:13:53 AM
Does anyone have Revit 2009, yet [ 1 2 ]
Thu, May 8, 2008 at 8:09:52 AM
23
Rendering in Revit 2009 [ 1 2 ]
Thu, Dec 31, 2009 at 10:41:31 AM
19
I need to open a Revit 2011 file into the Revit 2009 ? Are there any way ? [ 1 2 ]
Thu, Jan 6, 2011 at 3:25:02 PM
18
Page generation time: 1.7833
