44 Users Online (43 Members):
Forums >> Revit Building >> Technical Support >> trapezoid-shaped window
2 Posts No Rating |
Hello everyone is new forum and a novice in the field of revit. I wanted to ask advice on how to implement a trapezoid-shaped window. The fact is that a model I have found, but the probblema is that even setting the materials I want when not render them keeps me but I leave a window frame with white when I had set as wood and glass while gray should be transparent. Rigrazio already and I hope all of riuscie to resolve this probblema
![rkitect Avatar](user_avatar/4651.jpg)
![4 Stars: 29 Votes](/images/stars_4.gif) |
Are any of your other materials in the model rendering correctly? The symptoms you describe occurs most commonly when a material is missing from the accurender/mental ray library. If this is not the cause, you need to look into the Settings>Object Styles dialogue. This window will allow you to set different model categories up with different materials. Specifically, you should look at Windows>Frame/Mullion. Be sure you have the correct material setup in this dialogue. HTH, GL!
You fell victim to one of the classic blunders. The most famous is never get involved in a land war in asia, but only slightly less well known is this! Never go in against a Sicilian when death is on the line! |
2 Posts No Rating |
Thanks for the advice I managed to solve my probblema. Thank you
Trapezoid shaped Wall-Foundation or floor slab-edge!! [extra reinforced rib] |
Wed, Feb 6, 2019 at 7:54:58 AM
Problem with U-shaped stairs |
Tue, Jul 9, 2013 at 8:10:56 AM
trapezoid thickness of the wall? |
Fri, Mar 6, 2015 at 1:37:45 PM
To create an egg-shaped mass? |
Mon, Aug 27, 2012 at 5:16:05 PM
window sills |
Sun, Jun 18, 2006 at 5:16:17 PM
Members: | 2022340 | Objects: | 22974 | Forum Posts: | 152200 | Job Listings: | 3 |
