49 Users Online (47 Members):
Forums >> Revit Building >> Technical Support >> How to reduce lineweight for filled region
HI, Can anyone guide me on the issue below? I have to reduce the lineweight of filled region pattern. Is there anyway to make it halftone? Thnx in advance
Now on the implementation stage.... |
Hi, Try selecting it , right click , overide grafics in view, by element, there you can set it to halftone, in the normal properties you can olso set the color to white to make it invisible ( dunno if it will print white / invisible)
"There is no path to peace,
peace is the path."
Mahatma Gandhi.
That makes the boundary line as half tone also. I only want my hatch pattern to print lighter. Any other suggestion plzz thnxx
right click , overide grafics in view, by element, and set the surface pattern to grey or yellow or whatever,,,
peace is the path."
Mahatma Gandhi.
Remove Model Filled Region @ Fixtures |
Wed, Aug 15, 2012 at 4:19:33 PM
Deleting Types From Filled Region Families |
Tue, Sep 9, 2008 at 6:56:41 PM
filled region pattern color changes when drawing scale changes |
Thu, Apr 14, 2016 at 7:32:06 AM
Lineweight on Surface Patterns? |
Mon, Jun 15, 2009 at 11:54:52 AM
Tracing filled regions with linework |
Tue, Mar 3, 2009 at 10:24:52 AM
Members: | 2017723 | Objects: | 22948 | Forum Posts: | 152213 | Job Listings: | 3 |
