48 Users Online (47 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> The 'F' Key
Wed, May 28, 2008 at 8:32:47 PM | The 'F' Key
teddynugget
teddynugget Avatar
3 Stars: 2 Votes
Does any one have a problem with their keyboard not responding in Revit 2009,
i know you're probably thinking its nothing to do with Revit, but it's the only program we have this problem in and it happens on both computers that are running it.
The problem is that the keyboard stops responding after a short period of time in the program, shortcuts won't work, can't type text etc. for some reason if we hit the 'F' key it makes the keyboard work again for a short period until it eventually stuffs up again.
Its not a major problem but it gets annoying.
Permanently unchecking the 'Editable Only' box
Mon, Oct 27, 2008 at 11:39:20 PM
''Visibility grafics'' and ''create parts'' problem when mak
Fri, Mar 19, 2021 at 11:45:46 AM
Adjusting height of key frames in walkthroughs
Mon, Aug 1, 2011 at 2:18:11 PM
Add ''scale'' on a drawing list, when it is not under ''available fiel
Thu, Jan 12, 2012 at 8:35:32 AM
Sheet 'X' of 'Total Number of Sheets'
Wed, Jun 5, 2013 at 4:39:34 PM
Page generation time: 2.2280
