Forums >> Revit Building >> Technical Support >> Why can't you upgrade your file to 2009? - I DID!
Wed, May 28, 2008 at 5:03:21 PM | Why can't you upgrade your file to 2009? - I DID!
RevItUp
3 Stars: 2 Votes
Workset enabled project.
5 levels
1.2 million SF per floor
Structural is a separate Linked File (Foundation, Steel Columns, Beams, Joists & Floors)
Site is a separate Linked File
~140 MB file (210 MB when not compressed and being used with links loaded)
 I did all of the standard stuff to prepare my 2008 file for upgrading to 2009.
1.  Backup the original File (Just in CASE!!! CYA!!!)
2.  Open in 2008 with Audit and Detach from Central.
3.  Purge Unused!
4.  Uload all Links using Managed Links dialog.
5.  Only have a single View open (I have a drafting view with text only just for saving).
6.  Save the file with Compaction turned on.
7.  Open Revit 2009 and then open the File.
 ...tried to upgrade the entire project file with no luck...
 I even made sure there were no WARNINGS!
3.5.  Fix all warnings
Then I tried another thing.
4.5.  Removed all links.
After racking my brain against the 3 24" monitors that are on my desk and tring to upgrade a number of times, I sent the file to AutoDesk.  2 weeks +  and they still have no answer on the file. I tried a couple more times, thinking maybe I needed to reboot, or close all my other programs, etc. etc.
I figured there has to be some object that is stopping it, it would get to about 75% and then crash everytime.  So I thought... mmm... what if I took all the 3D objects out of the equation?  I have been working with linked files and groups and relinking and binding for a while now, and have had a lot of success with taking items out of the project and bringing them back in as if nothing ever happened, i.e. wall top and base constraints the same, so I figured I would try this approch!
2.5.  Grouped logically related parts of geometry together (did I mention this project is approximately 5,000,000 sf?).  Well, that meant I created a curse-load of Groups: then saved the groups out as Links!
I repeated this a number of times; until only Levels, Grids and Annotations, Views, Sheets realistically everything shy of the actual building, existed in the original file.
Opened Revit 2009...tried to upgrade the now building-less project file with luck... (Yes I said WITH luck, now we are getting somewhere).  Hip Hip Hizaahh! Hip Hip Hizaahh!
8.  Upgrade each of the linked group files, one-by-one (with no Crashing)!  Hip Hip Hizaahh!
9.  Re-Linked all the Grouped Linked Files into the new 2009 main file, Bind them, and finally Ungroup them and...
It F*$#ing worked!!! ... Relief!... Hip Hip Hizaahh!
( I now have to replace 2 of my 3 24" LCD monitors oops)
 So here are the steps that I took and in the final order.
3.  Grouped logically related 3D parts of geometry together then convert to Links!
4.  Repeat step 3 until only Levels, Grids and Annotations, Views, Sheets are left.
5.  Unload all Links using Managed Links dialog (Remove all links is better).
6.  Purge Unused!7.  Fix all warnings
8.  Only have a single "TEXT" Drafting View open.
7.  Open Revit 2009 and then open the File to upgrade it.
 I hope this helps someone else out there!
John Raiten
Gensler
Las Vegas, NV
Edited on: Wed, May 28, 2008 at 5:10:17 PM
Edited on: Wed, May 28, 2008 at 5:11:58 PM
Mon, Aug 25, 2008 at 7:05:10 AM | Why can't you upgrade your file to 2009? - I DID!
SteveB
3.5 Stars: 5 Votes
I am having a similar problem.  Much smaller file, 50 MB.  An r2008 file, trying to open in r2009, it crashes on opening.  I tried the audit and open.  Crash!  Oddly it opened and worked for about a half a day.  I also backed up a copy and now even clean original copies of this file won't open.
 I tried re-downloading the whole r2009 program from autodes, as suggested by the crash diaolog.  No go.
 Is any one else having problems opeing r2008 files in r2009.  Any documented fixes?
Sat, Nov 8, 2008 at 10:10:30 PM | Why can't you upgrade your file to 2009? - I DID!
3ab8ari
The Revit consultants -in general- recommend that to not upgrade the Revit version, and carry it till the end of the project. As odd as that sounds... The reason ? the exact problem you are having. Files won't upgrade, or upgrade and go corrupt due to size and errors and conflicts...etc. If you want to try upgrading, make sure all users are out of the central, that you have backed up all your models, that you have enough disk space, that you purge and compact your models, that you are aware of all the complex and odd areas of your model to check them after the upgrade (design options, curtain walls, groups, specially treated walls ...etc.) One major issue in Revit is the template. It still a mysterious subject whether a template file can be upgraded (successfully) because we worry about certain hidden limitations remain. We create a new company template every new version. (this also reminds me to warn users to NOT use a different discipline template, i.e. SAVEAS the Arch model into RST model to create the Structural model. You MUST start RST model with RST template - we already made this mistake !)
Revit Upgrade from 2009 to 2012
Wed, Oct 19, 2011 at 7:08:21 AM
UPGRADE QUESTION
Mon, Jun 12, 2006 at 9:03:39 AM
UPGRADE problem!!!
Wed, Jun 28, 2006 at 6:35:24 AM
error message prevents upgrade to revit 2009**
Wed, Jul 23, 2008 at 9:04:28 AM
Upgrade Revit 2009 to 2012
Wed, Feb 1, 2012 at 1:32:00 PM
Page generation time: 0.9614
