63 Users Online (62 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Railing Components
Mon, Apr 4, 2005 at 12:30:08 PM | Railing Components
mharris
Does anyone know how to use the baluster-panel component template? i'm trying to create a railing system and i have know idea what i'm doing. the panel template has reference panels set up for horizontal and diagonal panels. how do i make the to work together?
Mon, Apr 4, 2005 at 7:33:34 PM | RE: Railing Components
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
If you open some of the baluster families included in the default libraries that come with revit you may get a better understanding. As for the angled reference planes these are for the cut of the baluster for ramps/stairs etc. You usually have to associate a void to these reference planes to cut the post. The horizontal reference planes define the height of the element. HTH.
Tue, Apr 5, 2005 at 12:38:26 PM | RE: Railing Components
mharris
is there any way to bend a panel in a corner instead of using a baluster?
Tue, Apr 5, 2005 at 6:25:18 PM | RE: Railing Components
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Create a baluster that is a bent panel and set it as the corner post...?
Tue, Apr 5, 2005 at 6:28:09 PM | RE: Railing Components
mharris
Thanks, that's what I thought. I'll let you know how it turns out.
Thu, Apr 7, 2005 at 10:49:21 AM | RE: Railing Components
mharris
Well, that worked, but it was a little difficult. I had to break the guardrail in the middle to get the middle panel to work correctly. So it is in 2 pieces. Thanks for your help.
Fri, Nov 11, 2005 at 12:30:18 PM | RE: Railing Components
david5555
Hi MHarris, I have the same problem as you, and it appears you solved it. I can not get my paenl to run upstairs correctly and to breakright. I was wondering if you could post the baluster corner panel and the regular panel so I can analyze your solution. At corners the panel does not break. Thanks. I hope that is not too much too ask. D
Fri, Nov 11, 2005 at 12:49:04 PM | RE: Railing Components
mharris
SURE THAT'S NOT A PROBLEM. I HOPE THIS IS THE RIGHT ONE. IT'S BEEN A WHILE. IF YOU ARE STILL HAVING PROBLEMS I MIGHT BE ABLE TO POST THE WHOLE RAILING. THAT WAY YOU CAN SEE HOW I PUT IT TOGETHER. SOME OF MY RAILINGS GOT SO COMPLICATED I HAD TO JUST DO THEM AS GENERIC COMPONENTS, AND NOT USE THE RAILING COMMAND. IT JUST SIMPLY COULD NOT DO IT. AT LEAST I COULDN'T GET IT TO DO IT, OR IT WAS JUST FASTER TO DO IT AS COMPONENTS.
Fri, Nov 11, 2005 at 1:15:02 PM | RE: Railing Components
david5555
Interesting. Thanks. It appears as the right one. Now did it creep up stairs correctly or did you not have any stairs? If it isnt a hassle please post the whole rail. Maybe I should just do as you did and use a generic component. Was that 'in place' family?
Fri, Nov 11, 2005 at 2:28:14 PM | RE: Railing Components
mharris
NO THAT PANEL WASN'T ON A STAIR, IT WAS A GUARDRAIL CONDITION. FOR THE STAIRS, I USED THE RAILING COMMAND ONLY FOR THE ACTUAL HANDRAIL, BUT FOR THE GUARDRAIL PART, I MADE IT W/ A SERIES OF COMPONENTS THAT I MADE AND THEN INSERTED INTO THE DRAWING. HOWEVER, I EVENTUALLY DIDN'T USE THE HANDRAILS I MADE WITH THE RAILING COMMAND, BECAUSE I COULDN'T GET THEM TO WORK RIGHT. YOU KNOW BREAK WHERE I WANTED THEM TO, AT THE DIFFERENT HEIGHTS. WHAT I EVENTUALLY DID WAS IN PLAN VIEW, AND SECTION, ELEVATION, WHATEVER, I DREW THEM USING FILLED REGION. ANYWAY, ABOUT THE GUARDRAILS, I MADE THEM AS A GENERIC COMPONENT. I DIDN'T USE THE BALUSTER TEMPLATE, AND MADE THEM ADJUSTABLE. I THEN LOADED THEM INTO THE DRAWING, AND PLACED THEM WHERE I NEEDED THEM, AND ADJUSTED THEIR SIZE AS NEEDED. IT JUST WAS EASIER AND FASTER THAT WAY. HOPE THIS HELPED. IF YOU STILL NEED THE WHOLE RAILING SYSTEM FOR A LEVEL GUARDRAIL CONDITION, LET ME KNOW AND I'LL UP LOAD IT FOR YOU
Fri, Nov 11, 2005 at 2:32:58 PM | RE: Railing Components
#11
david5555
Thanks alot. I have spent enough time on it. What I will do is use the railing command for the regular pattern (w/o panel) and then use component to show the panel that are irregular. I Almost got it to work, but it just wont end correctly and trucate the pattern, though it flexes right in the baluster family, angle and all. I am convinced it needs to be updated in a new release. Thanks again for taking time to help. Happy Reviting. D
Fri, Nov 11, 2005 at 2:35:34 PM | RE: Railing Components
#12
mharris
NOT A PROBLEM. I'M GLAD I COULD HELP.
Railing not shown in list
Mon, Jun 30, 2014 at 4:25:57 PM
rectangular railing
Mon, Nov 26, 2012 at 7:30:08 AM
Railing Turns Into Transparent Red
Thu, Aug 10, 2017 at 2:06:42 AM
Railing and Baluster Profiles not inserting on centerline?
Fri, Oct 5, 2012 at 2:26:21 PM
Newbie help: how to intersect railing with baluster
Wed, Mar 25, 2009 at 4:26:54 AM
Page generation time: 0.6934
