70 Users Online (66 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> exterior trim
Tue, May 27, 2008 at 9:10:00 PM | exterior trim
smartDESIGN
I am a new user of Revit 2009.  I am limping through a handful of residential projects that I have begun.  How do I make corner trim on an exterior wall with siding?  How about adding a frieze board to where the wall joins to the roof on the gable side?  On the eaves?
Wed, May 28, 2008 at 2:05:39 PM | exterior trim
Bm3875
Bm3875 Avatar
4 Stars: 7 Votes
#1) Create a profile of a corner trim piece and assign it in a wall sweep and place it as a verticle wall sweep at the corner. The trim piece will wrap from the host wall around to the perp. wall
#2) Create a wall sweep using a 1X12 (or whatever) profile and go to Wall Sweep>Roof Fascia and pick the lowest most line of your eave and offset horiz. by your overhange depth.
#3) The Eave sides will be a simple horizontal wall sweep using the same sweep as the gable ends.
Hope this helps,
Brandon Pike | Owner/BIM Specialist
cad.web.print
website: http://www.thinkdesign-studios.com
blog: http://www.bimtionary.blogspot.com/
Wed, May 28, 2008 at 2:19:54 PM | exterior trim
smartDESIGN
Thank you for the very clear response.
Exterior Window Trim
Thu, Jun 22, 2017 at 9:17:08 AM
13
Exterior Cedar Trim
Thu, Aug 12, 2010 at 6:49:41 PM
Adding exterior trim to window
Tue, Nov 10, 2009 at 8:27:34 AM
Need footing at different elevations to trim
Thu, May 23, 2013 at 3:40:02 PM
Windows, Walls, Trim
Mon, Jun 9, 2008 at 12:15:01 PM
Page generation time: 0.7936
