68 Users Online (67 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Square cut on my roofs?
Tue, May 27, 2008 at 6:18:22 PM | Square cut on my roofs?
DLicata
DLicata Avatar
3.5 Stars: 7 Votes
I'm trying to get a square cut for my roof edges.  I tried the 3 options in the Roof Element Properties but none of them are what I need.  Is there any other way to get square cuts at my roofs edges?  Or am I just missing something here?
 LHAA
 Licata Hansen Associates Architecture
Reno, NV USA
Wed, May 28, 2008 at 7:42:35 PM | Square cut on my roofs?
mhans
3 Stars: 10 Votes
I use Roof by extrusion and "Cut Plan Profile. You can use a combination (Footprint & Extrusion) and join them if required. Can you show a screenshot?
Motto: "No Post left behind"
Thu, May 29, 2008 at 8:36:48 AM | Square cut on my roofs?
JustinT
Could do with a sketch of what you are after... but you can also use a Host Sweep> Fascia or Gutter from the Modelling draw to create the edge you desire... you will have to create a Profile first of course.
Justin
www.revitup.co.za
Thu, May 29, 2008 at 11:15:59 AM | Square cut on my roofs?
DLicata
DLicata Avatar
3.5 Stars: 7 Votes
Thanks for the help guys, I figured it out.
 LHAA
Reno, NV USA
Thu, May 29, 2008 at 12:02:19 PM | Square cut on my roofs?
mhans
3 Stars: 10 Votes
At least you can share your solution, since we have become a part of your troubles. Smile
Thu, May 29, 2008 at 12:14:25 PM | Square cut on my roofs?
DLicata
DLicata Avatar
3.5 Stars: 7 Votes
Haha your right, how rude of me. Smile
So I went to my roofs Element Properties and under Construction you have the option to change the Rafter Cut -Plumb Cut/Two Cut Plumb/ or Two Cut Square.  So I selected Two Cut Square.  At first it wasn't what I wanted but then I looked under Rafter Cut and saw the options associated with the Rafter Cut- Fascia Depth.  This becomes editable when you choose Two Cut - Square, so I messed with the Fascia Depth until my roof looked the way I wanted it to.  I put the Fascia Depth to 1'-6".
HTH
Thanks again!
 LHAA
Reno, NV USA
Thu, May 29, 2008 at 12:26:05 PM | Square cut on my roofs?
mhans
3 Stars: 10 Votes
Great! Thanks.
Thu, May 29, 2008 at 2:32:40 PM | Square cut on my roofs?
DLicata
DLicata Avatar
3.5 Stars: 7 Votes
Your welcome!
 LHAA
Reno, NV USA
Can't make a Two Cut - Square rafter cut on a roof
Fri, Jan 14, 2011 at 6:20:30 PM
Square Cut Rafters
Tue, Nov 20, 2007 at 5:45:45 PM
square cut on shed roof
Tue, Apr 10, 2012 at 4:21:54 PM
Custom Rafter Cut for plumb plywood and square standing seam
Sun, Dec 15, 2013 at 10:26:27 AM
RAC09 - Roof Fascia Corner Miter on Square Cut
Wed, May 27, 2009 at 6:57:00 PM
Page generation time: 0.7564
