44 Users Online (43 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Reflected Ceiling Plan Thoughts
Tue, May 27, 2008 at 1:28:29 PM | Reflected Ceiling Plan Thoughts
mflure
Greetings all,
Im using Revit Architecture 2008 (will be installing 2009 here within a week or so)
I had a crazy issues that reared its ugly head in a crunch time (like that never happens <GRIN>Winking, and I was wondering if anyone has come accross this and what solution you arrived at getting around it?  I got it out but it was not pritty.
First off the basic project information is an  Office T.I. approximatly 64,000 sq. ft.  It has a main open cubical area in the center with a 2x2 acoustical ceiling at 11'-9" a.f.f., Training classrooms surround the main area and also have 2x2 accoustical ceilings at 11'-8", but are on there own grids.  The model went in no problems but this is were it gets wierd and crazy.
Issue 1:  When I demo'd the grid the grid didn't display as dashed lines, which I suspect that this is because of the model hatch pattern.  I actually used a filter trick to turn off the demo'd ceiling and made line work to represent this (yes I know not the best idea but it worked for now)
Issue 2: Before I turned off the demo'd grid I had started to plug in the new light fixture locations in the revised ceiling plan.  The fixtures where actually cutting the existing grid even though they were in a phase in the future.  They didnt show the fixtures but it was defenatly cutting holes into the grid?  This I still have not found a work around?
 Sorry for the long post, but It's a weird issue to me.
Michael Flure
Tue, May 27, 2008 at 1:34:53 PM | Reflected Ceiling Plan Thoughts
hyperhydro
Hi, mflure,
I am a newbie here, didn't work much on "phase" yet. My thought is to use design options, which completely turn on/ off the geometry when you are switching between two options. So you won't have a collision between two options, like your lgiht fixture...
Anyone?
Reflected ceiling plan
Fri, Mar 28, 2008 at 11:16:26 AM
Cannot open reflected ceiling plan
Fri, Jan 9, 2009 at 2:23:07 PM
Problem seeing doors in reflected ceiling plan
Mon, Jul 14, 2008 at 9:26:12 AM
REFLECTED CEILING PLAN
Thu, Jan 20, 2011 at 3:12:51 AM
Different Plan Title for Reflected Ceiling Plan
Mon, Aug 1, 2022 at 4:28:33 PM
Page generation time: 0.7338
