Forums >> Revit Building >> Technical Support >> [Help] How to delete/edit Parameter setting in family editor
6 Posts No Rating |
Hi, guys, Anyone knows how to edit/delete parameters in family editor? I am creating new family called "awning", and created a parameter called "depth" to associate with depth of awning. But I gave it WRONG category of "other" instead of the Right one of "Dimensions". Now I can't delete it or edit it. The "depth" parameter shows up in family properties, under "Other" category. And I can't do equations with it. I tried my manual and searched Revit Help, but got no answer to this question. If someone knows about it, or can tell me where I can find the answer, that will be fantastic. Any input will help. Thank you,
Hi, in the left side pick in "FAMILY TYPES" then you can pick and edit or delete in Parameters...
6 Posts No Rating |
Never mind, I just got it. I snooped around, and found the remove button in family properties window.
6 Posts No Rating |
Thank you, Typhoon. That is a quick reply, like Typhoon.... cool.
Custom Type of Parameter in Family Editor |
Thu, May 14, 2015 at 3:03:40 PM
why can't i delete lines in family edit mode? |
Mon, Jan 1, 2018 at 6:26:55 PM
Delete (title block) family category parameter |
Thu, Aug 4, 2011 at 12:55:25 AM
Cannot create new types of family within the family editor (RA2009) |
Mon, May 4, 2009 at 9:22:59 AM
Cant edit family parameters? |
Wed, Jul 15, 2009 at 1:36:26 AM
Members: | 2115336 | Objects: | 23192 | Forum Posts: | 152320 | Job Listings: | 3 |
