Forums >> Revit Systems >> Technical Support >> Flat Roofs
3 Posts No Rating |
I have a flat roof that needs 2 slopes to join with and butt up against 3 sides of adjoining roofs but Revit only allows one of the other, they are on adjoining sides and they need to be in 2 different angles, does anyone know how this is done
Sorry, but your post is confusing. You say you have a flat roof but then you talk about slopes. Which is it, flat or sloping or multiple slopes? A plan diagram would help clearup things.
Yeah, it's really confused... put images to we figure out what do you need...
3 Posts No Rating |
The attached DWF indicates the problem in red, perhaps the correct term should be a flat roof with 2 inclines, I have managed one OK but when I place another it splits the roof and installs a rdige which I do not want.
Hi, i can't open this file.
3 Posts No Rating |
Try this one a PDF file in A4
Hi, now i can open, so, i think the best way to solve this problem is "Create in Place" that element because you have diferents declines and elevations, create a element (mass) it's more simple.
Revit 2008 Multiple Roofs on Same level? |
Tue, Jul 24, 2007 at 9:05:39 AM
12
flat roofs - best practices |
Mon, Jan 5, 2009 at 11:10:30 AM
Vallys in flat roofs? |
Wed, Aug 2, 2006 at 2:37:28 PM
flat roofs |
Mon, Mar 7, 2005 at 8:38:25 AM
flat roofs |
Wed, Feb 1, 2006 at 3:15:53 PM
Members: | 2115971 | Objects: | 23193 | Forum Posts: | 152301 | Job Listings: | 3 |
