147 Users Online (145 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Rotate dimension
Mon, May 26, 2008 at 9:07:29 AM | Rotate dimension
torstenk
Hi all
Take a look at the picture. Is it posssible to rotate the dimension text?
Mon, May 26, 2008 at 10:45:03 AM | Rotate dimension
Under settings, annotations, dimensions, you can set your dimension options but Vertical is not one of them.
Tue, May 27, 2008 at 1:46:39 AM | Rotate dimension
torstenk
So it is not possible to make the text horizontal?
Wed, May 28, 2008 at 9:17:08 AM | Rotate dimension
torstenk
Anyone?
Wed, May 28, 2008 at 10:42:43 AM | Rotate dimension
4 Stars: 203 Votes
I think WWWHub just respond to your question, you don't tell what version of Revit are you use but in 2008 it's not possible, i don't know in 2009, i don't have here this version... maybe latter i can responde you....
Wed, May 28, 2008 at 10:55:58 AM | Rotate dimension
brettgoodchild
brettgoodchild Avatar
4 Stars: 17 Votes
This could be accomplished very easily with a detail component line based family with nested annotations. Or just make a new dimension style with extremely small text and place you own text how you want it.
HTH
"You cannot escape the responsibility of tomorrow by evading it today. "
                             ~ Abraham Lincoln
Wed, May 28, 2008 at 12:07:55 PM | Rotate dimension
torstenk
Could explain this more?
Wed, May 28, 2008 at 12:51:25 PM | Rotate dimension
brettgoodchild
4 Stars: 17 Votes
See the video. You can make this much more complex using visibility parameters, maybe have it display the actual dimension but have an override parameter in there so you can have it display what you want. You can do a lot with this.
http://screencast.com/t/AKaroyWZf
HTH
                             ~ Abraham Lincoln
Wed, May 28, 2008 at 1:29:19 PM | Rotate dimension
brettgoodchild
4 Stars: 17 Votes
Perhaps you would like this one a little better. This one shows how to have the lable show the actual dimension and be able to switch between the text override and the dimension.
 http://screencast.com/t/1N7S2JGZ7gk
HTH
                             ~ Abraham Lincoln
Wed, May 28, 2008 at 2:39:49 PM | Rotate dimension
torstenk
Thanks for your reply brett.
Yeah it was what i was looking for. I just thougt you could make it easier. I thougt i had missed a option somewhere or something.
I hope that is something they will change.
But thanks for all your help Smile
Rotate of family
Wed, Feb 24, 2010 at 1:32:33 AM
ROTATE ELEMENT
Mon, May 16, 2011 at 8:15:09 AM
Activate Dimension
Tue, Dec 13, 2011 at 12:53:45 PM
Angle Parameter moves objects?
Wed, Jul 20, 2011 at 11:32:23 AM
3d rotate
Fri, Sep 28, 2018 at 7:16:27 AM
Page generation time: 0.3648
