61 Users Online (60 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Gross volume of a building
Mon, May 26, 2008 at 8:41:43 AM | Gross volume of a building
fredc83
How can I get the gross volume of a building out of revit?
I know how to find the volumes and areas for rooms and the gross area for the different floor plans.
Does somebody have an idea?
thx!
Mon, May 26, 2008 at 10:46:41 AM | Gross volume of a building
3.5 Stars: 395 Votes
You can have more than one area plan.  Just do an area plan but use the exterior of your building.
Tue, May 27, 2008 at 2:06:00 AM | Gross volume of a building
fredc83
thx for your reaction
I know it's possible to create another area plan from another level, but i am searching for a gross volume (inclusive exterior and interior walls) of my building.
Tue, Jun 3, 2008 at 4:59:13 AM | Gross volume of a building
fredc83
Does someone knows a solution for this problem?
Greetings
Edited on: Tue, Jun 3, 2008 at 4:59:44 AM
Tue, Jun 3, 2008 at 5:44:14 AM | Gross volume of a building
4 Stars: 201 Votes
Hi, draw the lines around the area you want, then go to "Room and Area" and pick "area Plan" and choose in Type:"Gross Building", go to "Area Boundary" and pick the lines you made before (around the model)  then pick "Area" and click inside the area....
Tue, Jun 3, 2008 at 2:50:08 PM | Gross volume of a building
TABEST
4 Stars: 4 Votes
To do this, as far as I understand, you need to perform some math.  Get the gross area for each floor, and in a schedule, create a calculated value, multiply the area by the height from floor to floor getting you volume.  Then You only need to get the grand total of the calculated value and you have your gross volume.
Tue, Jun 3, 2008 at 5:55:15 PM | Gross volume of a building
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
You could go through your room schedule and use the calculate totals to get the total volume of all your rooms.  However, as you have pointed out, this will be to the interior faces of elements and it is possible if you don't rooms everywhere to miss bits.
As such, when I've needed to do this previously I've just created a quick Mass form that filled the extents of my building and then went to its properties to find out its volume.  Depending on this complexity of the form this can be either really quick or a little tedius.
HTH.
Regards,
Chris.
Wed, Jun 4, 2008 at 1:41:10 AM | Gross volume of a building
fredc83
Thx a lot, I will try them out today Smile
first time using gross building area - whouldnt my shafts be deducted?
Wed, Mar 26, 2014 at 1:39:28 PM
Level Schedule
Mon, Feb 11, 2013 at 1:30:12 PM
Creating a Level schedule
Mon, Feb 11, 2013 at 1:29:09 PM
Gross areas & Phasing
Mon, Feb 23, 2015 at 9:14:01 AM
Gross Building Area Tag
Tue, Feb 2, 2010 at 12:06:25 AM
Page generation time: 4.6382
