79 Users Online (77 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Revit Roofing
Sun, May 25, 2008 at 7:23:57 PM | Revit Roofing
Nocsaron
I need to create a roofing plan, but all i can see is this "mass".  i have adjusted to cutplane, height, and depth properties to no avail. How do i see the beams that make up the roof?
Mon, Jun 2, 2008 at 4:55:05 PM | Revit Roofing
mhans
3 Stars: 10 Votes
Adjust view detail to fine. Check visibility for structural framing, column, beam systems.
Motto: "No Post left behind"
Tue, Mar 23, 2010 at 2:30:32 PM | Revit Roofing
ChelesaTheRad
Do you have a sheating on your roof? make sure that that is either off or transparent. Are you beams drawn as framing? you might also just turn the roof off, unless you want the vallys and ridges to show up on your plan. Make sure that Framing is turned on in your visibility graphics and that they are not hidden in view.
Roofing Material Look alike
Wed, Nov 21, 2012 at 5:35:58 PM
sloping roofing
Wed, Mar 9, 2005 at 1:21:53 PM
align Revit's asphalt shingle roofing in plan view to sloping side
Wed, Aug 12, 2020 at 4:47:29 PM
Altering roofing structure in section views R2012
Thu, Jul 19, 2012 at 7:32:51 AM
Tile Roofing
Wed, May 31, 2006 at 8:06:24 AM
Page generation time: 2.9818
