77 Users Online (76 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Revit 2009 material saving
Sun, May 25, 2008 at 11:56:35 AM | Revit 2009 material saving
lukaszsw
lukaszsw Avatar
3 Stars: 4 Votes
Is it possible to somehow save the materials other than leave them in the project and later tresfer them using the "trasfer project standards tool"?
Sun, May 25, 2008 at 12:43:07 PM | Revit 2009 material saving
4 Stars: 203 Votes
hi, Unfortunately it's the only way you save your materials (walls, doors, windows, and so one), because in this version THEY have the "GLOSSY IDEA" to remove from the program a "USER LIBRARY", in the other versions you have the possibility to save your materials in a "USER LIBRARY" BUT IN THIS "THEY" TOOK this possibility....
Sun, May 25, 2008 at 1:22:46 PM | Revit 2009 material saving
lukaszsw
lukaszsw Avatar
3 Stars: 4 Votes
I know, but than I don't want to go back to accurender.
It seems that this will be changed as there is an option in settings called "Render appearance library" which does absolutely nothing (only thing is to press ok), I would guess that this will be the place to import or save materials and perhaps synchronize with your main material library
Thanks, I wanted to be sure
Saving frpom 2010 to 2009
Wed, Jul 13, 2011 at 2:13:05 PM
Revit 2009- 'Cut-out' image for materials, faulty
Mon, Sep 29, 2008 at 4:13:56 PM
Revit 2009 Additional Material Request
Thu, Aug 7, 2008 at 3:21:22 AM
2009 subsurface material display
Thu, Apr 24, 2008 at 8:07:25 PM
REVIT 2009 - MATERIALS
Tue, May 5, 2009 at 10:01:40 AM
13
Page generation time: 2.1850
