44 Users Online (43 Members):
Forums >> Revit Building >> Technical Support >> Wood stair Family or Details
2008. I am not happy with the stair configuration and details created by the Revit modeler for wood stairs. they have some goofy elements in the model and can't make a simple wood stringer. riser and tread model to add vinyl floor and treads and risers!!.....any idea of other ones out there to assist me??? thanks for your help!!
8 Posts No Rating |
Hey, did you ever get a good answer?
For some reason, we can't add patterns to treads in stairs but they will render correctly.
I suggest you look at the example stairs (BTW - later versions are no longer posted so look in the 2009 library.)
The on-line library is here: http://revit.autodesk.com/library/html/index.html
The stairs and other items are under the Revit instruction and Help samples.
Can not swap out one stair family for another |
Thu, Sep 19, 2013 at 12:24:19 PM
Wood floor way too shiny. |
Tue, Dec 14, 2010 at 7:32:39 AM
wood deck family |
Mon, Nov 23, 2009 at 11:19:20 AM
How to Apply Wood Material to a New Family Member [ 1 2 ] |
Mon, Jul 13, 2009 at 2:18:09 PM
15
Wood Siding |
Fri, Nov 22, 2019 at 3:17:58 PM
Members: | 2022380 | Objects: | 22974 | Forum Posts: | 152201 | Job Listings: | 3 |
