128 Users Online (127 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> How to work with the elements from link
Fri, May 23, 2008 at 11:09:18 AM | How to work with the elements from link
Rams
3 Stars: 3 Votes
Hi,
Can anyone guide me on process of working with elements from revit link?
For example if i want to switch off few elements from a particular category say structural framing then how it would be possible? If its a live element then we can simply do hide in view but it doesn't work with link.
Thnx in advance
Now on the implementation stage....
Fri, May 23, 2008 at 3:55:44 PM | How to work with the elements from link
Look in your VG for the view.  There is a REVIT link tab.  It is set to the default of using the host's display's settings.   Click on that and change to custom.  In the following screen, again change the  setting to custom and you can now set the linked file's VG for anything.
Tue, May 27, 2008 at 2:39:49 AM | How to work with the elements from link
Rams
3 Stars: 3 Votes
Thnx hub. I am known to this option. Ok let me describe in detail what i want.
I am getting all the structural beam from the link file. I want to see only those beam which are cutting in section and would like to hide the beam in elevation..
Any suggestions
Tue, May 27, 2008 at 6:56:36 AM | How to work with the elements from link
My answer is the obvious.  Turn them all all then hide in view the ones you don't want.  REVIT doesn't perform miracles either.
Tue, May 27, 2008 at 8:10:48 AM | How to work with the elements from link
Rams
3 Stars: 3 Votes
If i select and do hide in view then all the elements from the link model turned off. Whereas i want to hide only few of them. I think we can only turn off the category not the individuals in the link file.
Tue, May 27, 2008 at 8:43:18 AM | How to work with the elements from link
As of 2008, you can individually hide each selected element in view.  You do not need to hide category.
Tue, May 27, 2008 at 12:14:44 PM | How to work with the elements from link
Rams
3 Stars: 3 Votes
I may be wrong but i think we cannot select the individual element coming from the link model.
When I import REV. ARCH Link, it lands way outside my work space
Fri, Oct 9, 2009 at 12:22:41 PM
Turn off the same linked elements in every view [ 1 2 ]
Thu, Nov 29, 2012 at 2:51:09 PM
23
2015: selecting elements in link
Tue, Nov 18, 2014 at 1:17:27 PM
12
link visibility
Wed, Jan 19, 2011 at 12:57:55 AM
Reflected Ceiling Plan not showing revit link elements
Tue, Dec 7, 2021 at 6:55:57 AM
Page generation time: 0.8585
