175 Users Online (173 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> two seperate rooms but with one room tag
Thu, May 22, 2008 at 3:19:39 PM | two seperate rooms but with one room tag
tonyL
how do you tag a space with 2 rooms but only show one overall tag???
(one room tag to represent the two rooms - in total area)
please help.
Thu, May 22, 2008 at 4:01:29 PM | two seperate rooms but with one room tag
dhulsberg
First select the wall that is between the two rooms and go to its element properties.  Then uncheck the "Room Bounding" box.  This removes the area defining attribute of the wall and should going the two areas into one.  Hope this is what you were looking for.
Thu, May 22, 2008 at 6:37:49 PM | two seperate rooms but with one room tag
mhans
3 Stars: 10 Votes
Use Room separation line and hide them in view. This would create to rooms in one space.
Motto: "No Post left behind"
Thu, May 22, 2008 at 6:56:08 PM | two seperate rooms but with one room tag
tonyL
thanks guys
it works perfectly.
Matching Room Numbers in Area's and Room Tag
Thu, Jun 12, 2014 at 10:12:09 AM
Room tag not showing in only one room. [ 1 2 ]
Sun, Apr 6, 2025 at 9:54:40 AM
26
Room Tags -
Thu, Aug 30, 2018 at 11:26:11 AM
Room Tags - Tagging Multiple Rooms as One
Tue, Feb 19, 2008 at 1:25:29 PM
Room Tag Dilemma
Thu, Jan 12, 2012 at 7:55:54 PM
Page generation time: 1.5608
