32 Users Online (30 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Split Facing and Painting both sides of a wall?
Thu, May 22, 2008 at 1:35:57 PM | Split Facing and Painting both sides of a wall?
malsscho
So I'm painting walls and in order to paint appropriate section, I have used the split face command to do this.  I have one wall that is shared between two rooms and I want to paint each side of it.  However, if I split face one side of the wall and paint it (it appears correctly), and then go to the other side of the wall to do the same thing, nothing appears.  Revit let's me enter the split face sketch mode and draw lines, but when I finish the sketch no lines show up.  I've tried to still paint and it looks as though it selects it, but doesn't paint anything.  I've tried just painting the wall on the other side instead of using split face, but still nothing.
 Can anyone tell me why I can't paint both sides of the wall?  It is just a generic 6" wall.  Would it help to seperate the structure of the wall into 2 - 3" generic pieces?
Help!
Thu, May 22, 2008 at 3:28:36 PM | Split Facing and Painting both sides of a wall?
JAMESHGRIMES
JAMESHGRIMES Avatar
4.5 Stars: 10 Votes
This may sound like a stupid question but; Are you splitting the correct face. Sometimes you have to tab to select the correct face. That being said I am not sure why the paint command isn't working properly. The method you described is the same that I use and I haven't had any problems with it. If you could post some screen shots of the sketch mode and of the paint selection I might be able to diagnose the problem.
Thu, May 22, 2008 at 3:32:11 PM | Split Facing and Painting both sides of a wall?
malsscho
Thanks for your response.  Another user pointed out this same thing to me and that was the problem.  Because I was selecting the face in elevation, it wouldn't always grab the appropriate one.  I've been verifying it in 3D now and it seems to be working.
 Thanks again!
Fri, Jan 13, 2017 at 10:52:51 PM | Split Facing and Painting both sides of a wall?
suzypasko
I had the same problem - couldn't split the second side of the wall. With your solution (3D and select the correct face), it's solved. Thanks.
painting split walls with windows
Thu, Nov 15, 2012 at 3:17:05 PM
Modifying Split Face
Thu, Feb 18, 2010 at 6:07:11 AM
Splitting a wall with a Reveal
Fri, Feb 19, 2010 at 11:25:45 AM
unlock finish materials on both sides of wall
Wed, Mar 30, 2011 at 4:14:43 AM
Stop Revit from Painting outside of Split Face region
Wed, Feb 12, 2025 at 4:12:51 PM
Page generation time: 0.7443
