100 Users Online (99 Members):
Forums >> Revit Building >> Technical Support >> Symbols in Schedules
10 Posts No Rating |
I am using RAC09, Is there a way to add an image or symbol into a schedule. We use a large dot symbol in the column under the header on our room schedule and I have not yet figured out how to get it to work in REVIT. Any ideas? Thanks
If you make a yes/no field, you get a check box..... I know - it doesn't look the same as the dots we used to use but visually it works. You might want to register the option to change this in the AUGI wish-list area.
Thanks for the info. I will put that on the wish list.
Annotation symbols and schedules. |
Wed, Aug 13, 2014 at 3:48:34 PM
Deleting import symbols |
Thu, May 8, 2008 at 3:14:21 PM
symbols, detail components |
Mon, Jan 23, 2012 at 6:35:40 AM
SYMBOLS |
Fri, Mar 6, 2009 at 11:02:48 AM
Electrical symbols - scaling |
Tue, Feb 5, 2013 at 7:18:56 AM
Members: | 2017134 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
