Forums >> Revit Building >> Technical Support >> Ramp railing
is it possible to attach a railing to a ramp after having deleted the automaticaly created railing when the ramp is first created? Kind regards
"There is no path to peace,
peace is the path."
Mahatma Gandhi.
Hi, yes it's possible, go to rails and after, pick in "HOST" and select the ramp....
tnx, sometimes a railing on a ramp is taking a dive to the base level and some meters later jumps back up, or just doesnt follow the slope of the ramp. ever seen this? and what can i do about it, ?
peace is the path."
Mahatma Gandhi.
Yeah, sometimes the rails had this "madness", in ramp or stairs, but if you choose "HOST" and select the obj. "He" respect the slope...
nope doesnt always work correctly. Would appreciate somebody taking a quick look at it, tnx!!
peace is the path."
Mahatma Gandhi.
Hi "Daf", i see your file and now you can see that's correct, when the rail is "broke" (turn other direction) it's when revit begin "confusion", the best way is edit this rail, delete the segment was wrong, close, then create another segment by "Host"....
Flat Railing with a ramp as a host |
Mon, Dec 27, 2010 at 6:27:11 PM
Offset Railing Height |
Sun, Feb 1, 2009 at 4:47:25 AM
wall railing for ramp |
Wed, Dec 18, 2013 at 1:52:55 PM
stair and ramp railing |
Sat, Sep 9, 2006 at 3:41:33 PM
Stair-ramp-landing Problem |
Mon, Mar 24, 2014 at 11:13:25 AM
Members: | 2104630 | Objects: | 23178 | Forum Posts: | 152303 | Job Listings: | 3 |
