37 Users Online (36 Members):
Forums >> Revit Building >> Technical Support >> Ok, here's a Rendering (How do I get the lights to come on??!!)
16 Posts No Rating |
Ok here is one of my first renderings with Revit 2009. The Image is set as: Interior - Sun & Artificial. The Time is set for 1 Hour, between 4:00 and 5:00 P.M. I have Daylight Portals for Doors and Windows set as well. How do I get the interior lights to come on?? Why don't they render? PLEASE Help? Image is attached
![3.5 Stars: 3 Votes](/images/stars_3.5.gif) |
After setting the image to sun & artificial click on the artifial lights box in the rendering dialog. You need to create a new group with all your light sources checked 'on'. Make a new group, then highlight the group and click edit and add the lights. Or after creating the new light group, close the rendering dialog box and highlight the lights and change the group in the toolbar dropdown menu. hth
Hi, i try with the 3 option and you can see in image attach, this work fine, when you use "Sun Only" you don't have the choise to turn off the interior light, i don't no if it's a "bug" but..., see also (after do what "BDerrick" says) what kind of light do you have in your model, select one of them and go properties and check the values of watts, lumens and so one...
rendering: can't get itnerior lights turned off |
Mon, Feb 27, 2012 at 6:14:44 AM
Ceiling Lights don't self-illuminate |
Mon, Oct 17, 2011 at 10:21:44 AM
lights not working in 3D or rendering |
Thu, Jul 11, 2013 at 10:56:36 AM
interior rendering, lights won't come on |
Thu, Apr 25, 2013 at 10:42:56 AM
Exterior night rendering with interior lights on? R16 |
Wed, Aug 3, 2016 at 1:23:36 PM
Members: | 2017275 | Objects: | 22947 | Forum Posts: | 152212 | Job Listings: | 3 |
